Old 01-28-2012, 03:41 PM   #1
Adding a Outlet to a box with a switch
Hi!
I live in an older house and in the kitchen there is only one outlet. To make things easy I want to add an outlet right next to the light switch.
In the bow where the switch is there is one set of wires one wire is black and the other is white. How would i wire it so that I can have an out let that is always hot and the light still be operated by the switch?
twmorga is offline   Reply With Quote
Old 01-28-2012, 03:44 PM   #2
Julius793's Avatar
Originally Posted by twmorga
Hi!
Are there any other wires in the back of the box? If not it won't be possible.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-28-2012, 04:14 PM   #3
joed's Avatar
Two problems.
1. Only two wires indicates a switch loop. There is no neutral so you can't add a receptacle.
2. It's the kitchen. Kitchen receptacles are not permitted to be on a circuit with anything else. You can't have them on the same circuit as the lights. You need to pull a new #12 cable from the panel for your new 20 amp kitchen circuit.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
Jim Port (01-28-2012)
Tags
adding new wall plug, old house outlets
Adding an outlet from a switch skdiy Electrical 18 01-15-2012 05:12 AM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 07:25 PM
