Adding An Outlet To A Bit Of A Mess... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2014, 02:13 PM   #1
Rewards Points: 121
Adding an outlet to a bit of a mess...
Hey there.
So, I'm helping someone add an outlet so that they can wall mount a flatscreen TV. The outlet we're going to tap off of is a little bit of a mess.
There are 3 sets of 14-2 coming into the box and they're all wired into the outlet using one set of side screws and both sets of the push in terminals on the back of the outlet.
Here's where I need the reassurance:
Remove all of the wires from the old outlet, add a 4th set of 14-2 (for the new outlet), cap all of the hots, neutrals, and grounds, and give the old outlet pigtails. I figured this might be a better idea than just adding a 4th set of wires to the outlet.
Does that sound OK?
Thanks so much for the help!
mikeyp78 is offline   Reply With Quote
Old 06-24-2014, 02:41 PM   #2
Rewards Points: 6,652
That current box is most likely not big enough for the extra run of Romex. Now of course as for how the outlet is wired. Those romex that are backstabbed, need to be cut off, and Pigtails need to be used.
How are your Drywall patching skills? Can you get to the Romex run from underneath and maybe put in a junction box there, so you can pull a run of 14/2 up to the outlet behind the tv?
The Following User Says Thank You to gregzoll For This Useful Post:
mikeyp78 (06-24-2014)
Old 06-24-2014, 03:41 PM   #3
Rewards Points: 338
At first it might seem like the right thing to do, but you've probably already noticed the box is kinda tight. The pig-tailing is a good idea. Is there another location you could remove some of those wires to, so as to relieve some of the over crowding? Or change the existing box to a 2 gang box and add another outlet? (I'd go with option 2). When you bring your new wires into the 2 gang box make them about 12" long or more (out of the box). About six inches out, use your strippers to strip the wires about 3/4" (you're basically going to be pushing the insulation along the wire). Wrap that around the screw terminals. About 4" from that, strip the wires again and then wire nut it to the rest of the conductors. If you're going to make it a 2 gang, repeat the step before wire-nutting. If they have grounds you'll have to use a green wire nut (the one with the hole in the middle), to connect your grounds.
gregzoll beat me to it while I was writing and editing this. He already addressed some of the things in my post...
petey_c is offline   Reply With Quote
The Following 2 Users Say Thank You to petey_c For This Useful Post:
gregzoll (06-24-2014), mikeyp78 (06-24-2014)
Old 06-24-2014, 08:36 PM   #4
Rewards Points: 121
So, really the main concern is having enough space (and being up to code) for all of the wires that are going to be in the gang box? The wiring itself, as long as it is done correctly obviously, is the smaller concern.
Thanks for your help.
The Following User Says Thank You to mikeyp78 For This Useful Post:
Old 06-25-2014, 07:38 AM   #5
DIY staff
Rewards Points: 7,174
There is a lot going on there---have you checked the outlet side tab?
Make sure that is not a half switched outlet---
mikeyp78 (06-27-2014)
Old 06-27-2014, 02:11 PM   #6
Rewards Points: 121
I ended up pulling out the old box and replacing it with a 2-gang box. I pigtailed all of the groupings of wires together with the large blue wire caps (per the recommendation of an electrician I was talking to in the aisle at HD). Added the new 14-2 line and outlet. Everything works beautifully. Thanks for all of the advice, folks!
wkearney99 (06-28-2014)
adding a switch to an outlet with two circuits jeffpeter Electrical 16 12-10-2012 08:38 PM
Adding An Outlet Off Of Switched light austinbblock Electrical 4 07-23-2012 12:16 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Adding an outlet tunaman Electrical 6 01-30-2011 01:10 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
