Adding Outlet For Above Stove Microwave - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 02:39 PM   #1
Adding outlet for above stove microwave
First let me start by saying, I don't know much about home electrical wiring, but I can do simple things like replacing outlet boxes and light switches.
I'm redoing our kitchen, removed the old hood with exhaust fan over the stove, it was hard wired by two wires (black and white) covered with a flexible metal sheeth (which I'm told is the ground) coming out of the wall. I bought a new "over the oven" microwave which has a standard 3 prong plug.
My question is, can I just install an RFI outlet using those just those two wires coming out of the wall, install the box in the cabinet above the microwave and plug it in? The power supply for the two wires is on the same breaker as most of the kitchen, (not stove or dishwasher, which have their own), but the lights and other electrical outlets.
bobbysan is offline   Reply With Quote
Old 04-28-2010, 04:16 PM   #2
Where are you located ?
Old 04-28-2010, 06:00 PM   #3
Journeyman Wireman
Rewards Points: 150
Is this a microwave & hood fan? Or is it just a microwave sitting on a shelf above the stove?
For a micro/hood fan unit consult the installation instructions. Most require a dedicated circuit and cannot share with other outlets in the kitchen.
Jupe Blue is offline   Reply With Quote
Old 04-28-2010, 06:54 PM   #4
San Diego
Old 04-28-2010, 06:59 PM   #5
Yes it's a hood fan also, but now I'm realizing that when I flip the breaker only the hood fan and the lights (have 3 flourescent fixtures with 6 four foot bulbs) go out. All the outlets are still on. Not sure that makes any difference.
Regardless, okay let's just say I want to connect my blender to it, can it be done?
Old 04-28-2010, 07:07 PM   #6
DIY staff
Rewards Points: 7,174
Many of the new microwaves draw enough anps to pop the breaker if the circuit has any thing else on it.
You could take a chance on the existing wiring---but the kitchen is under construction--now is the time to do it.
Or you could wait till every thing is finished and freshly painted and then run a new line.--Mike--
Old 04-28-2010, 08:01 PM   #7
I may be wrong but I think a MW/hood combo requires a dedicated circuit
If I have read it right the code now requires a dedicated circuit for a plug in exhaust fan
Since your MW includes an exhaust fan a dedicated circuit is required 422.16
The Following User Says Thank You to Scuba_Dave For This Useful Post:
oh'mike (04-28-2010)
Adding an outlet for above the range microwave casl37 Electrical 17 03-06-2010 08:57 AM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
Gas Stove Outlet and Over the Range Microwave theatretch85 Electrical 6 04-24-2009 09:25 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
