Adding An Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 10:09 AM   #1
Rewards Points: 109
Adding an outlet
Need to add an outlet on my bedroom circuit. I have an outlet box that's easy to get to which has two cables going into it. Can I just run an additional cable into it (assuming the box is large enough, or I can replace the box) and run it to the new outlet?
BimmerRacer is offline   Reply With Quote
Old 09-01-2009, 10:22 AM   #2
Basically - Yes
More in depth - you need to make sure that the box is big enough & has enough volume to fit all the wires
Each box has a different fill capacity for the number of wires/devices
Is it a metal box, blue box ?
Old 09-01-2009, 10:26 AM   #3
Rewards Points: 109
Originally Posted by Scuba_Dave View Post
Basically - Yes
Neither plastic gray. The back of the wall is exposed so I can easily put a metal 4x4" box.
Old 09-01-2009, 08:05 PM   #4
dSilanskas's Avatar
Yes you can
dSilanskas is offline   Reply With Quote
Old 09-01-2009, 08:54 PM   #5
Then you can more easily put a single gang plastic nail on box.
What is the fascination with metal boxes
220/221 is offline   Reply With Quote
Old 09-02-2009, 09:02 AM   #6
I find the strain relief for plastic boxes to be less than sufficient. I also do not like the thickness of the of the flange when they are used as an old work box.
RetiredKeith is offline   Reply With Quote
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 01:53 PM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
