Need to add an outlet on my bedroom circuit. I have an outlet box that's easy to get to which has two cables going into it. Can I just run an additional cable into it (assuming the box is large enough, or I can replace the box) and run it to the new outlet?
Basically - Yes
More in depth - you need to make sure that the box is big enough & has enough volume to fit all the wires
Each box has a different fill capacity for the number of wires/devices
Is it a metal box, blue box ?
I find the strain relief for plastic boxes to be less than sufficient. I also do not like the thickness of the of the flange when they are used as an old work box.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
