Adding Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 07:24 PM   #1
Rewards Points: 83
Question
Adding outlet
I just finished installing the new box and running the wires to add a ceiling fan and just noticed that I bought 12/3 wire and I guess I have a little smaller 14 wire existing...thought it was 12 when I checked...Is this a problem and need to get the same size wire or is one size up going to be ok. I took power from a switched outlet to power a new ceiling fan with two switches. Thanks for the help.
jstcruzin is offline   Reply With Quote
Old 07-13-2008, 07:34 PM   #2
Longtooth's Avatar
12/3 is good, Side wire only.
Longtooth is offline   Reply With Quote
Old 07-13-2008, 07:46 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
As long as you don't put a 20 amp breaker on 14g wire, you're OK. 14g only allows 15 amp breakers.
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-13-2008, 08:42 PM   #4
Rewards Points: 83
Nope, i wont be changing anything else, keeping all the outlets and breakers the same just adding on the one set of wires for the ceiling fan. I dont know much about electrical but i didnt think it was a big deal but would rather get good word on here to be safe...Thanks a lot!!
I must say this site has been awesome for everything...so glad I found it...and you guys reply so quickly!!
Old 07-13-2008, 09:05 PM   #5
Power Gen/RS Engineer
Rewards Points: 566
Just remember: When it comes to wiring, bigger is always better (which makes you wonder why the AWG numbers get bigger as the wire decreases gauge). No man could ever forget this rule.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-13-2008, 11:51 PM   #6
Rewards Points: 83
Works like a charm...thank you!! On to the next one...tomorrow.
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
