Adding An Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 11:02 AM   #1
DIY
Rewards Points: 39
Adding an Outlet
Is it ok to add pigtails in the middle of an outlet daisy chain to add in another outlet? I have some older wiring in a home and i'm unsure where the last outlet is in the run. Is it ok to take one of the outlets, add a pigtail to the wires, and then run a separate wire to a different outlet?
Is that not recommended, or is it ok if the box has the space to hold the extra wiring?
RocketManZ is offline   Reply With Quote
Old 12-09-2011, 11:50 AM   #2
jproffer's Avatar
Rewards Points: 706
As long as:
1) all the boxes involved have room for the addition.
2) all splices are in boxes (whether the originals, or a new one with a blank cover) and NOT behind the wall.
3) The new conductors are sized correctly (or just use #12 to be safe).
I can't think of any reason why you couldn't.
jproffer is offline   Reply With Quote
Old 12-09-2011, 12:39 PM   #3
DIY
Rewards Points: 39
Originally Posted by jproffer View Post
As long as:
Thanks for the info. So just to make sure I understand correctly, the pig tail and the extra #12 wire can be in the same receptacle box behind an existing receptacle, right? Or are you saying that I need to run to a separate junction box and then make the pig tail splice?
Old 12-09-2011, 12:43 PM   #4
jproffer's Avatar
Rewards Points: 706
You can put it in one of the existing boxes as long as the box fill limit is not exceeded.
Old 12-09-2011, 01:06 PM   #5
DIY
Rewards Points: 39
Perfect,
Thanks!
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Adding outlet to existing circuit. Which way? noone Electrical 10 06-30-2011 09:16 PM
Adding outlet for above stove microwave bobbysan Electrical 6 04-28-2010 07:01 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
