Adding An Outdoor Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 10:18 AM   #1
Adding an outdoor receptacle
I plan on adding an outdoor receptacle for landscape lighting, holiday lighting, etc... and I just wanted to run down my plan before I get started, to see if anyone can correct or point out any mistakes before they happen.
I am going to tap into a non-GFCI receptacle in my finished basement, and run Romex up through the drywall, and out the wood siding.
I am going to place a plastic outlet box, the "remodel" kind, flush mounted in the wood siding, and run the cable through the box, hooked up to a GFCI receptacle.
I am going to cover the receptacle with an "in-use" plastic box.
Is this it?
thanks for any and all responses.
Mr. Michael is offline   Reply With Quote
Old 04-14-2009, 11:34 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Not sure what you mean a remodel kind. You will need a weatherproof box and the rest of your plan will work!
Good Luck!
Old 04-14-2009, 05:18 PM   #3
dSilanskas's Avatar
Yes you are correct
dSilanskas is offline   Reply With Quote
Old 04-14-2009, 05:53 PM   #4
Rewards Points: 2,350
Good Luck!
He means he is going to cut an old work box into the siding, and cover it with an In-use, or "bubble" cover.
Old 04-14-2009, 10:42 PM   #5
jbfan's Avatar
Rewards Points: 152
Gotcha
Adding a exhaust fan Oswald Electrical 6 03-29-2009 08:40 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
adding lights mharwell01 Electrical 1 01-03-2009 04:59 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
Adding A Ceiling Fan To Living Room jte1130 Electrical 1 05-28-2008 04:05 PM
