Adding Onto A Switched Controlled Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2008, 02:06 AM   #1
Adding onto a switched controlled circuit
I have a switch that controls the bottom outlet of two wall receptacles and I would like to have the same light switch control three new recessed lights I am going to put in.
Current wiring coming into the light switch is a three wire strand(red, white, and black) with the red wire being inserted into the top of the light switch and the black into the back bottom of the switch and the white connected to the white wire leaving the box. The black wire leaving the box is screwed onto the side of the switch. If I didn't make it clear there is only a two wire strand leaving the box.
Do I just need to pig tail off of the black and white wires leaving the box or do I need to connect a the black wire to the new lights to the switch some where.
Thanks in advance
Sparky08 is offline   Reply With Quote
Old 06-27-2008, 06:43 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Thanks in advance
Run 2 wire to the first recessed can, at the switch connect the new white to white, connect the new black to the red. Run 2 wire from the first can to second and subsequent cans. BTW, you are saying your existing wiring is stranded. If existing wire is run in conduit and your city requires it, all added wiring should be piped also. Otherwise you can run cable.
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 10:27 AM
Adding a receptacle to existing circuit dekohl Electrical 3 09-10-2007 02:46 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
Adding a new circuit breaker ksl420 Electrical 9 05-23-2006 11:25 AM
