Old 11-08-2012, 02:51 PM   #1
Adding a new switch and LED's to a circuit
Hi all, Im attempting to add a new light switch and under the cabinet LED lights to the end of a circuit of power outlets and having problems doing the wiring:
I have one set of 12-2 wires (w/ground) coming into the double outlet to which I have (or would like to) place a new box in the wall next to the outlets in which I want to add a single switch which will turn off/on the LED lights under the cabinet.
So it would be: incoming power - (already there) double outlet - (add new) switch - transformer with LED's.
I believe this is at the end of a circuit.... I was hoping to not go up into the ceiling and just jump the power to the switch from the outlets. Is this possible?
Not sure how to wire the outlet and switch... May have bitten off more???
Nicky4 is offline   Reply With Quote
Old 11-08-2012, 02:53 PM   #2
Licensed electrician
Lighting cannot be added to the 20 amp small appliance circuits in a kitchen.
taco sr503-4 switch jmon HVAC 53 11-12-2012 07:26 PM
Can I use a simple on/off switch? R083RT Electrical 6 05-10-2012 11:11 PM
Covering LEDs with insulation MiamiWay Electrical 5 02-10-2012 11:33 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 03:39 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
