Adding new/separate circuit breaker.............
I have my home theater system in my front room and if I have it all on and turn say something on that takes some juice on in the garage it trips the breaker...so I wanted to add a separate breaker for the outlet in the front room. My question is...is there a easy way to find out which wire goes to that outlet, also should I run a standard 15a breaker? My system is HK receiver, 10" powered sub, DVR, Media Center PC, XBOX 360, and Blu-ray. I can run all of it fine until something on that same circuit with some juice kicks on. My understanding is find the wire at the box, (of course after shutting off power) and connecting that to a new breaker in the panel, and installing it. Im comfortable doing the work, Im just not too experienced in electrical work although Im learning quick...
