Adding New Receptacles/ Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 12:24 PM   #16
Licensed electrician
Rewards Points: 1,738
You need a grounding means in the wiring method. Switching to a 3 prong receptacle will not provide a ground.
What wiring method does your house have?
federer (01-24-2013)
Old 01-24-2013, 01:26 PM   #17
Rewards Points: 4,796
(He already said his wiring is 2-wire, no ground. Why does he "need" a grounding means? These things are grandfathered in....)
Never mind! Sorry, got this confused with another thread.....
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 01-24-2013, 03:01 PM   #18
Rewards Points: 968
yea we would like to make it a 3prong receptacle
federer is offline   Reply With Quote
Old 01-24-2013, 03:07 PM   #19
Rewards Points: 968
so back to original issue: i just went all over the house switching breakers off and trying to trace where circuits go. so in the back of the house above the ceiling there is a circuit running horizontal and then down into the wall it looks like. my guess is this line feeds the recptacles in the other room. here is a pic:
so you see the line disappear down into the stud. my guess is it runs to the first outlet in the adjacent room, and so forth. now there is 4 outlets in that room. so by my guess i traced it to the last outlet in the room, and open it up. this is what i find:
so am i right to think this is the last outlet on the circuit? if so, i would like to use this one as my source for my new lights. i am only adding 2 lights to the ceiling. is this ok?
Old 01-24-2013, 03:14 PM   #20
Rewards Points: 968
to make it more confusing, there is this one running down into teh stud as well on the same back of the wall as the white line in the picture above. in this pic it's a black line, so does this mean this is the true hot, and the other line going horizontal is just neutral???? i am really lost!
Adding an Outlet in my Attic pittjosh81 Electrical 6 05-13-2012 08:44 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Rewiring - adding receptacles, paths to use RST Electrical 2 03-14-2010 02:29 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
