Adding New Receptacle And Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 07:06 PM   #1
Rewards Points: 12
Adding new receptacle and switch
Hello, I would appreciate any pro electricians to check my proposed wiring.
I need to add a new receptacle and switch to my AV closet by tapping into an existing circuit.
The receptacle will be to power the AV gear, and the switch will turn on/off a cooling fan.
Assuming that there are no wiring errors in the attached drawing, then:
Question - Where should I wire the switch to for power? Box1, Box2, or directly to the receptacle in Box3?
*NOTE: This is a Home Automation switch, so it has Black, White, Red, and Green wires
8888 is offline   Reply With Quote
Old 02-05-2012, 04:29 PM   #2
Rewards Points: 12
Here is another drawing as my brain sees it.
Notes:
* Existing Romex is approximately 2' from Box 3, and once cut there will not be enough slack to do anything but box each end.
* This is NOT a regular switch. It has 4 permanent wires coming out BWRG, there are NO terminals.
http://www.smarthome.com/2476S/Switc...g-White/p.aspx
Let me re-ask the question:
1) Is the shown new config2 correct.
2) If there is another way, what is it, and why is it better or more correct.
3) Goal = New leg works, and my house won't burn down.
I'm not an electrician, so please keep answers at novice level using colors and/or drawings if possible
Many Thanks
Old 02-05-2012, 04:41 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Your 2nd picture looks doable,but again id tail the wires before 1st plug instead of using it as a connection point
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 05:10 PM   #4
Rewards Points: 12
Sorry, I don't understand, any chance you could draw your reply?
Old 02-05-2012, 05:15 PM   #5
plummen's Avatar
I have a tough enough time typing,let alone drawing pictures!
Wire nut the wires together before the plug
Old 02-05-2012, 05:53 PM   #6
Rewards Points: 12
Is this what you mean?
Old 02-05-2012, 07:55 PM   #7
joed's Avatar
Rewards Points: 11,988
Pigtailing or wire nutting is a personal choice. It is not required and in Canada wire nuts count towards box fill so it is better to use less of them.
Old 02-05-2012, 09:12 PM   #8
plummen's Avatar
Yes thats the way I was thinking
Old 02-06-2012, 12:27 AM   #9
Rewards Points: 264
I'm also a fan of less wire nuts when possible. However, one problem with your drawing number 2, which you fixed in drawing 3, was having 2 wires connected to the outlet's ground screw. You can only have 1 wire per screw, so you need to wire nut in this case.
One question, is this AV fan 120V or lower?
a_lost_shadow is offline   Reply With Quote
Old 02-06-2012, 03:13 PM   #10
Rewards Points: 12
Thanks to all that replied to this post.
- My reasons for drawing 2 over 3 has EVERYTHING to do with the number of wire nuts. If you have never installed a Home Automation switch or receptacle there are things to be aware of:
1) They are bigger [deep]. They limit the amount of space to tuck your wiring. I have installed many into existing boxes that are already full of wiring and you must cram it in hard just to mount them. Pushing so hard can/will loosen the existing nuts, usually the large bundle of neutrals. I have solved that problem by using Ideal® Push-In connectors. They form a permanent connection, and take up little space. I use them almost exclusively to make connections.
2) They have wire leads not terminals, so you will always have a minimum of 4 connections. I never got an answer as to why pigtailing is better, more professional, code requirement, easier...? If this were a standard switch, your tails would go directly to the screws, eliminating the need for the nuts, but that is not the case here. So it seems that tailing [drawing 3] would add a problem, not solve a problem.
@ a_lost_shadow
Not if the ground is long and wraps around the screw, then continues. I guess I could also tail all the grounds together. ±? Not sure if that benefits me?
@ a_lost_shadow
The fan is a bath type exhaust fan 120v, 20w, .19a. Why do you ask?
So, based on the Q&A, I'm I safe to go with either version of #2? [long ground or tail'd grounds]
Old 02-06-2012, 03:48 PM   #11
Rewards Points: 264
True, I'd forgotten about wrapping the ground around the screw. The previous owner of my house did that, but without providing enough additional wire to properly pull the outlet out. Thus I wrongly lumped it in the bad idea box.
I asked about the voltage of the fan since some of the home automation stuff I've looked at drops to lower voltages. Then you get into a different set of restrictions for class1, class 2, & class 3 circuits.
As for the tails vs. screws, the only reason I've heard to go with tails is its easier to leave a slightly loose screw connection. Then your outlet will heat up whenever any outlets farther down the line pull a load.
Old 02-06-2012, 08:33 PM   #12
Rewards Points: 12
I am getting hammered on other forums for not using pigtails. It's pigtails, or you are a hack!
Can any pros out there explain all the pros and cons. Is it easier, faster, cheaper, or is it truly the only way to wire without causing electrical problems, fires?
I don't care which way, its the same amount of work for me. ALL I care about is that it is done safely.
I have added another drawing of what I understand a pigtail config would look like. My novice logic is to daisy chain, IN >> to the top screws, OUT >> from the bottom screws to the next device.
HELP!
Adding new receptacle and switch-recepswitch2.jpg   Adding new receptacle and switch-recepswitch4.jpg
Old 02-06-2012, 10:49 PM   #13
plummen's Avatar
I prefer tailing the wires out before plugs,that way youre not using the plug as a junction point.
Ive had to repair/replace enough back fed plugs and swithes over the years that people installed that got hot and burned up internally killing everything past that point
Old 02-06-2012, 11:02 PM   #14
joed's Avatar
Some people are just set in there ways. If they like pigtails then you won't convince them screw terminals are just as good.
Back stabs are a bad idea. Screw connections are just as good as pigtails.
Old 02-06-2012, 11:18 PM   #15
plummen's Avatar
City of Omaha has required plugs to be tailed out for atleast the last 20 years,no using plugs to daisy chain outlets
Adding a receptacle from existing switch themow Electrical 8 11-14-2011 09:16 AM
Switched Outlet, Power into the switch then to switched receptacle ryanwake Electrical 1 01-23-2011 01:52 PM
Adding a light between a light switch and the receptacle it controls jej2csi Electrical 3 11-24-2010 08:06 AM
Adding a Hot Receptacle to a 3-Way Switch Coady Electrical 2 09-03-2010 01:11 PM
Adding a Hot Receptacle to a 3-Way Switch rtyui2 Electrical 11 11-21-2007 09:08 PM
