Adding New Group Of Lights And Switch To Existing Light Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2015, 01:50 PM   #1
Rewards Points: 211
Adding new group of lights and switch to existing light circuit
Hi all,
Racking my brain trying to find the best way to add a new switched group of lights (in closet) to an existing circuit. I don't want them to be a 3 way switch. What is the best way to continue the circuit and supply power to the new lights? I've attached a (crude) diagram for reference. Do any of these options work?
1) Run wire from the old lights down to the new switch (s2)?
2) Run wire from old lights to new lights down to the new switch (s2)?
3) Run wire from old switch (s1) to new switch (s2) to new lights?
Which of these options would work best? Which option would be a "switch loop"?
Thanks as usual for your expert advice!
gtothek is offline   Reply With Quote
Old 05-11-2015, 02:41 PM   #2
joed's Avatar
Rewards Points: 11,598
Only option 3 will work unless you want the new lights to also be switched by old switch. You only have switched power at the old lights. Your source of unswitched power is at the old switch.
Option two would be considered a switch loop since you go to the lights first.
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 13 11-13-2015 05:14 PM
Adding under-cabinet lights to existing circuit. stupid48 Electrical 2 07-12-2014 08:09 PM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
