Adding New Gfi And Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 12:27 PM   #1
Adding new gfi and light switch
I have an already existing attic fan installed that is dead. Eventually I will replace it. But for now I want use the already pulled power and use that for a new junction box for a gfi and light switch. I want to add the gfi and a light in the attic. Below are three pics of what I have to work with. Pic one is the junction box where the power is coming from (back). Pic 2 is the other side of that box where a light fixture is. You can see that there is a ground wire attached to the box However that ground is in the romex line that was used to power the fan. And pic 3 is the thermostat box the romex was pulled to for the fan....
My question is as follows: is that romex actually grounded? Because I don't see anything grounding that junction box for it to simply be grounded by screwing into the box?
Obviously I need a ground source for the new work I want to install. So I wanted to check here first to see if this was an ok ground source to be using?
Back of box. Romex out is the power source for the fan
Front of box. That bare copper ground screwed in is the romex. Which on the other end was screwed in to the thermostat box for the fan which u can see in pic 3
Thermostat for fan with romex coming in and the other side of that ground wire. Screwed in.
Greenie is offline   Reply With Quote
Old 01-17-2012, 01:07 PM   #2
Julius793's Avatar
If the wire is ac cable (bx) the the grounding looks fine but I would check it with a tester to make sure
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-17-2012, 01:09 PM   #3
Julius793's Avatar
What kind of screw is that connecting the ground in the 2nd picture?
Old 01-17-2012, 02:05 PM   #4
Completely agree with Julius793 - it looks like it should be fine as the ground chains through, but you'll never know until you test it.
DIYWorker is offline   Reply With Quote
Old 01-17-2012, 05:15 PM   #5
New question..... How do you connect these wires to have them fit in this connector piece. Pig ails too big.
I had to connect two different flex to pull enough to a socket for a tv.
I need left side to power up and connect to the right flex.
Old 01-17-2012, 05:27 PM   #6
Licensed electrician
Rewards Points: 1,746
You cannot splice in a coupling. You need to use a box.
Old 01-17-2012, 05:28 PM   #7
then why would the idiot electrical store guy sell me this and tell me to use this when i told him i have two pieces of flex that need to be connected?
Old 01-17-2012, 08:20 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Right there!
That is two different sizes of wire.
All connections have to be made in an accessible junction box.
Old 01-17-2012, 11:18 PM   #9
Originally Posted by jbfan
Right there!
Same size wire. It's the same flex just cut too short so had to add more wire to reach the junction box.
Old 01-18-2012, 12:26 AM   #10
Julius793's Avatar
Because he's not an electrician they don't know bettter. Btw this cable is called mc metal clad. And the outer jacket may not be used as a ground as opposed to ac cable.
Old 01-18-2012, 06:16 AM   #11
jbfan's Avatar
Rewards Points: 530
That is not the same size wire!!!
Old 01-18-2012, 10:08 AM   #12
Lol I totally appreciate the fact that you are 1000% more knowledgable then I am in all aspects of electrical and most other home DIY improvement..... But I do have to tell you I cut the 20' flex cable I personally purchased with the blue red green white and black wire already In it....I cut it too short so I had to reconnect the wires and extend it further. If that is in fact the case.... How can it not be the same size wire??? ;-)
Old 01-18-2012, 10:19 AM   #13
Julius793's Avatar
Is there a red wire on both sides?
Old 01-18-2012, 10:41 AM   #14
Rewards Points: 3,256
I've been waiting for someone to comment on that round metal connector. Is that an electrical item and what is it used for?
zappa is offline   Reply With Quote
Old 01-18-2012, 10:53 AM   #15
jbfan's Avatar
Rewards Points: 530
The round thing is a screw on connector to join two pieces of pipe.
Why did you buy mc cable with red, blue, blacke, white and green, when all you needed was black, white, and green?
The Following User Says Thank You to jbfan For This Useful Post:
zappa (01-18-2012)
