Adding New GFI Circuit To Existing Sub Panel. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 04:50 PM   #1
Adding new GFI circuit to existing sub panel.
Existing 100A sub panel is fed by three #4's in metal conduit. I presume the conduit is acting as the ground. I want to add two circuits that will need GFI protection:
1) Is the sub panel correctly grounded as is? -- (the existing feeds are hard piped also).
2) New circuits will be Romex and not in conduit. Do I need to add a grounding bar to the box for the GFI's or can their grounds share the neutral bar?
spudgun is offline   Reply With Quote
Old 10-12-2012, 05:00 PM   #2
Rewards Points: 14,306
Might want to post a picture of the panel with the cover removed for better ansewers.
Old 10-12-2012, 05:08 PM   #3
Licensed electrician
Rewards Points: 1,876
Neutrals and grounds cannot share the same bar in a subpanel.
Old 10-12-2012, 05:22 PM   #4
Not sharing the same bar in a sub panel makes sense. Given that the box is grounded, when I add a second bar is it bonded (screwed) to the box like the neutral bar, or is it somehow isolated?
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 03:06 PM
Adding Light to Existing Circuit NEWJACK Electrical 2 05-11-2012 12:09 PM
Helping adding a light to an existing 3 way circuit. McSooner Electrical 4 12-03-2010 09:54 AM
adding a new circuit breaker panel Lana65 Electrical 0 09-23-2010 04:39 PM
