Old 11-20-2011, 10:16 PM   #16
Adding new GFCI outlet to existing light switch
Well, there is a way I think:
You can re-purpose the white to be neutral by connecting it to the neutral in the light fixture junction box. This gives you power/neutral/ground in the switch box itself.
Now, how to switch the light? Add a UPB or Insteon light fixture module for the lamp (there are modules that are designed to fit into the light fixture junction box) and wire in a corresponding UPB/Insteon switch in parallel to the GFCI. Now the light is controlled solely by powerline signals.
kwilcox is offline   Reply With Quote
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Light controlled by switch, outlet always on, power at light...is this the way? pureevil Electrical 6 11-07-2010 06:32 PM
Outside: Adding an outlet to a switched light fixture indigo Electrical 9 12-15-2009 10:48 AM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
