Adding New Ceiling Light In Place Of Switched Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2008, 09:06 PM   #1
Adding new ceiling light in place of switched outlet
Hello, In the process of remodeling the to-be-baby's-room and having trouble wiring the lighting, hoping someone here can help.
The room previously had a switch on the wall that controlled the top (only) of an outlet for a lamp, and I have opted to install a ceiling light while remodeling so I installed the fixture in the ceiling and fished the wire down to the existing switch. The current wiring configuration is as follows:
Switch location has new 14/2 coming down from new light fixture + old 14/2 coming from outlet. (Power source at outlet, I also replaced old outlet with a new one hoping to have it converted to always-on.)
Outlet Location has 4 -sets of 14/2 coming in, 3 whites are pigtailed together with one coming out of pigtail going into outlet, and 3 blacks + a last white are pigtailed together with one coming out of pigtail going to outlet, the last black is going directly to the outlet.
I purchased a dimmer switch that has black/green/red wires coming off of it, and connected the whites in the box to eachother, then connected the black from the new switch to the black from the old 14/2, and the red from the new switch to the black that runs up to the new light.
I'm pretty good with DC power but AC is a mystery, I'm sure the problem is that the power isn't coming out of the original outlet location to the switch location and I'm not sure how to change it to make that happen. I'd prefer to keep the use of the outlet but if bypassing it completely is the only way to get the ceiling light working that's fine.
Thanks for any help,
Xavier
XavierG35 is offline   Reply With Quote
Old 02-13-2008, 09:24 PM   #2
joed's Avatar
Rewards Points: 11,598
You need to rewire at the receptacle. Connect all the white together and all the blacks together. You also need to replace the receptacle as the tab on the hot(gold) side will be cut off to make the receptacle half switched.
Previously you had a switch loop send hot to the switch on the white wire and coming back switched on the black wire.
Old 02-13-2008, 10:05 PM   #3
Thanks so much, twisting them together did it no prob.. I had already changed the outlet so everything is working fine now..
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 11:30 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Turning Switched Outlet Into Ceiling Fixture 39centstamp Electrical 10 06-08-2007 01:07 PM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
