Adding New Breaker(s) - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 12:28 PM   #1
Question
Adding new breaker(s)
I live in a three story building in Brooklyn, NY and it seems to be a bit foolishly wired. Currently, every outlet (except for one) on the first and second floor are all going to one breaker. I'd like to add more breakers for obvious reasons.
How simple is this to do? Does it require rewiring things in the walls or does it just require opening the breaker box and somehow separating out some wire to their own breakers. I'm not 100% sure if they're good or not but there are also already several breakers in the box that don't seem to be connected to anything.
Thanks for any insights!
voltage2 is offline   Reply With Quote
Old 06-01-2011, 12:51 PM   #2
Licensed electrician
Rewards Points: 1,498
If there are multiple wires connected to one breaker you should be able to split some of the load there. If not some rewiring would need to be done to get a clable from the part to part of the circuit.
Adding 2 quad breakers. tattoojoe Electrical 4 10-10-2010 07:04 PM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
adding more breakers, few ?? mferguson0414 Electrical 12 01-17-2009 09:31 AM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
