Old 03-24-2012, 12:19 PM   #1
Rack em :)
NetTractorTalk's Avatar
Adding a new bathroom. Lots of questions
I had a bathroom roughed in when we built this house.
All plumbing was roughed in and an electrical junction box was put in for the electric.
I plan to have two lights beside the mirror and one light overtop. Plus an overhead light light near the center of the room, and a fan light combo. I would like to have 3 switches by the entry door to control all of these.
One switch would turn on the lights around the mirror
One switch woudl turn on the light in the center of the room
and one switch to turn on the light fan combo.
Plus I would have two outlets by the vanity, and two or three outlets across the room. Would all these outlets need to be GCFI?
What size wire would I need for all this?
How would I run it all? Guessing I would do the outlets in series with one jumping to the other all around the room. The switches I would go from the junction box with 3 wires (one for each switch) then from each switch to the device they would control.
Am I on the right track?
NetTractorTalk is offline   Reply With Quote
Old 03-24-2012, 12:30 PM   #2
Licensed Electrician
k_buz's Avatar
All bathroom recepts need to be GFI protected and no recepts are allowed over the tub or in the shower (if there is one).
As far as wiring, you sound like you are on the right track, but the size of wire is a little bit tricky. You said that there was power brought there already. Is that power a separate 20 A circuit from the panel or does it come from another bathroom?
If it is a separate 20 A circuit from the panel, you can put the entire bathroom on that circuit and wire everything with 12-2 romex.
If it comes from another bathroom, you can only use it for the recepts in the bathroom and the lighting must come from another circuit (wire size dependent on what that circuit is rated for (most of the time 14-2 romex would be used))
k_buz is online now   Reply With Quote
Old 03-24-2012, 01:10 PM   #3
Rack em :)
I 'think' it is it's own circut but can't say if it is a 20amp or not. I'll check that out.
I understand I'll need all GFI outlets and will not put any over the shower that is also being installed.
I have nothing and wonder what all supplies I will need from the store to do this project. If any special tools would make the job easier please mention them also. TIA!!!!!
Old 03-24-2012, 01:43 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
For our bath, the lights and fan are on the same circuit as the bedrooms (15 amp), the two outlets are on a 20 amp circuit. Only one outlet needs to be a GFCI, any others have to piggy back off the gfci and can be standard outlets, but must be TR (Tamper Resistant), same for the GFCI.
I really wish that I had placed one more outlet in my bath, so that you have one on the wall to your left as you walk in, for plugging in either a vacuum, or in the case that someone later one would need to place a heater for the bath, for medical reasons.
As for the lighting, we have the first switch turns on the overhead light, second turns on the light above the mirror, third turns on the fart fan. Everything was ran with #12 romex, 12/3 to the fan/light combo.
As for supplies, if electric has already been ran, you just need to get the fixtures, etc. Our bath came out around $2500 for all materials.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 03-24-2012, 02:01 PM   #5
Rack em :)
We are already over 2500 ... I'd guess we are at 4k, but still plenty to buy. I have the faucet for the vanity but need 3 shower faucets for the shower. Still have to pay for the drywall to be hung and finished. I have the drop ceiling and mohawk flooring, yet to be installed.
The supplies I was asking about were to run the electric from the junction box throughout the bathroom. I guess it's just wire, boxes switches and outlets. Interesting that I could make due with one GCFI outlet but what does tamper resistant mean?
Old 03-24-2012, 02:22 PM   #6
Licensed electrician
Tamper-resistant receptacles have shutters in the slots to prevent things like keys being inserted to help prevent shock hazards.
Old 03-24-2012, 02:42 PM   #7
without knowing where your junction boxes are heres a crude lighting diagram:
hammerlane is offline   Reply With Quote
Old 03-24-2012, 03:01 PM   #8
Rack em :)
Thanks Jim. Tamper resistant outlets are new to me. GREAT idea though. :thumb:
Thanks hammerlane for your drawing. That helps clarify things for me. Unfortunately, the junction box is across the room from where the switches will go. So I will need four outs from the junction box ....one for each switch and one for the outlets. Does that sound right, and it that in good practice ...or do I need to do it another way?
Old 03-24-2012, 03:42 PM   #9
Msradell's Avatar
It would be easier to just leave the first box with two wires. Use one of them to daisy chain the outlets (put a GFCI in the first one) and the other one would go to the switches. You can just pigtail from it to feed the three switches, like shown in the sketch above.
Msradell is offline   Reply With Quote
Old 03-24-2012, 04:04 PM   #10
You could run 4 cables from your juncton box but why?
You only need one hot conductor at the "3 switch location"
Once the hot conductor is there, use 3 pigtails attached to it. One for each switch.
Real difficult to give good advice without knowing where the incoming power is at in relation to all other junction points(fan, all lights, switches)
Old 03-24-2012, 04:20 PM   #11
Rack em :)
I thought of that but was not sure I could safely do it that way. When you say it it seems like Duh, sure that is the way to go. Thanks.
The room is 13 x 12. junction is in the vicinity of where the vanity and toilet would be on the east wall. the door is way across to the north wall with the tub on the south wall and leaving room for a sauna in the south west corner and a 3' closet in the north west corner. Dizzy yet. LOL. Hope that helps.
Your drawing did help for sure. With GFCI and all I thought I had to have 12 3 wiring. Good to know 12-2 will work. Wiring sure is expensive. Is there a cheap place to buy quality wire? Are the big box stores about as good as it gets?
Old 03-25-2012, 12:55 AM   #12
Price for wiring relies heavily on the quantity you want to buy. For the quantities most home owners use, the big box stores seems to have the best bang for your buck. But still, I suggest checking any local electrical supply houses. They may have better prices.
a_lost_shadow is offline   Reply With Quote
Old 03-25-2012, 06:36 AM   #13
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Just remember that the junction box must always remain accesable to meet code.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-25-2012, 08:18 AM   #14
Rack em :)
Thanks lost shadow, I will check local also. I prefer to buy local if the prices are close.
Good point rrolleston. I did not know that but will remember your tip.
How do I take hot from one switch to another? Do all switches come with a pass through hookup or do I need special switches to be able to pass the hot through to another switch?
Old 03-25-2012, 08:43 AM   #15
gregzoll's Avatar
There are no special switches. When hooking up the three switches, you will use pigtails for the Black/hot, and the Neutrals will all tie together with a wire nut. Basically you are taking the Hot and splitting it three ways, so each switch has a hot.
Some bathroom design questions coderguy Kitchen & Bath Remodeling 7 03-29-2012 02:10 AM
ASBESTOS..... lots of questions. Dyoung Building & Construction 22 02-14-2012 06:15 PM
Plumbing Questions - Convert Upstairs Laundry Room to Bathroom mjp24coho Plumbing 3 01-02-2012 12:16 PM
Paint Bathroom Ceiling questions? Hypochondriac Painting 5 08-15-2010 05:51 AM
Adding a bathroom DDRowe Building & Construction 3 05-28-2005 07:51 AM
