Adding On To The Neutral Bus? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 11:51 PM   #1
Rewards Points: 83
Adding on to the Neutral Bus?
We have a Westinghouse B20 3040CT 200AMP main panel. Obviously it's a 30/40 panel. The Neutral Bus has only 20 spaces and I'm down to 2 spaces and need to add another 4 circuits or so.
There's room for the breakers, but not for the Neutrals. (The ground bar is in the same shape, but my panel allows me to double up on the grounds.)
So - what is the approved method for adding more wires to the Neutral bus?
The friendly electrician at the local home improvement store suggested a sandwiching / stacking a short ground bar onto the neutral bus ... ?
Any and all help would be appreciated.
Thank you,
simanco is offline   Reply With Quote
Old 06-19-2012, 05:06 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
If this is service equipment, I usually purchase an approved ground bar and install it, then put a #4 copper jumper between the 2 neutral bars.
If it's not service equipment, I'll purchase an approved "insulated" neutral bar and install a #4 copper jumper between the 2.
Let it begin!!!
wirenut1110 is offline   Reply With Quote
Need Neutral Connections - Installing Subpanel ctlu008 Electrical 10 01-01-2012 07:54 AM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 02:48 PM
installing new dedicated circuit - neutral bus full 7green Electrical 12 05-03-2011 01:32 PM
Induction Cooktop, no neutral (?!) andersol Electrical 7 09-28-2010 03:47 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
