Adding Motion Sensor To Coach Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2009, 10:29 PM   #1
Adding Motion Sensor to coach lights
Hopefully this is an easy one. I would like to ask your advise on adding a motion sensor (combo with a light sensor) to existing coach lights. I can get at the wires in between the light switch and the first light in the string. I think I can wire it fairly easily but I don't know where to find the right sensors and mounting brackets to make the job look professional, while keeping it low cost enough not to justify getting new coach lights with the feature built-in.
So maybe a $50-ish budget is in the right ballpark park for the sensors and mounting brackets. I've seen some of the sensors offered at the hardware stores as replacements but no one has a mounting bracket. I'm thinking of mounting where the freeze board meets the eve.
sstinman is offline   Reply With Quote
Old 09-22-2009, 08:49 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
will this do it
http://www.hzonlinestore.com/details.cgi?file=0.3.168
Mr Chips is offline   Reply With Quote
Old 09-22-2009, 09:44 PM   #3
Thank you, Mr. Chips. That will do nicely.
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Issue with two motion detector lights tmac42 Electrical 4 03-25-2009 08:17 AM
adding lights mharwell01 Electrical 1 01-03-2009 03:59 PM
Installing motion / security lights west-phoenix-az Electrical 2 07-11-2008 07:33 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
