Adding More Fluorescent Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 08:41 PM   #1
Question
Adding more fluorescent lights
In my garage I have 3 existing 48" fluorescent light fixtures. Each fixture has a run of Romex running from the fixture to a single junction box. This box also has the cable from the switch, so there are a total of 4 cables entering the box.
I want to add an additional 2 light fixtures that will be on the same circuit. This is a 20a circuit that has GFCI-protected outlets in the garage and is used primarily for a couple tool battery chargers, plus occasional shop-vac and air compressor.
What would be the best way to install these lights? Would I just make 2 more runs of Romex from the new fixtures to the jct box?
Thank you.
james_2449 is offline   Reply With Quote
Old 08-06-2009, 08:50 PM   #2
Electrician
Rewards Points: 778
You can either come out of the junction box or take a wire from an exisiting light.
darren is offline   Reply With Quote
Old 08-07-2009, 12:04 AM   #3
I thought about that, but wasn't sure if that would mean they're now in series, so if 1 goes bad then all 4 go out...would that be the case?
Thanks for your reply.
Old 08-07-2009, 12:07 AM   #4
No they'll be in parallel basically using the light as a junction box
Dominick is offline   Reply With Quote
Old 08-07-2009, 05:53 PM   #5
Electrician
Rewards Points: 778
Like said before it would not end up in series, it would take a little thinking and creativity to make something in series in your house wiriring. Most things are setup to be done in parellel, like your plugs for example.
Fluorescent Lights Will Not Work g8tkeeper Electrical 5 07-30-2009 03:17 PM
Adding two pole lights to garden. gante Landscaping & Lawn Care 2 02-22-2009 10:56 PM
adding lights mharwell01 Electrical 1 01-03-2009 04:59 PM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 03:09 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
