Old 04-29-2009, 12:27 PM   #1
Adding micro in older home
hey all,
I just put in a hood/micro combo and want to put it on a dedicated circut.
This is a older home that has somewhat been upgraded. (Most of switches are back fed,think that is the term) so the sub panel when I went to add the breaker and run new 12/2 had both white and common in the bus bar.
I guess my questions is when I run the new circut do I also put the white and green on that bar?
zombie911 is offline   Reply With Quote
Old 04-29-2009, 08:22 PM   #2
Ground (green or bare) goes to a lug or bus that is attached directly to the enclosure.
The white goes to the neutral bus which should be isolated from the enclosure in a sub panel.
Match the other circuits............. if they were done professionally.
220/221 is offline   Reply With Quote
Old 04-29-2009, 11:04 PM   #3
thanks for the reply,thats the problem they have green and white on the same lug. if I run the new circut can I just ground the ground on the box somewhere else in the box and run white to the common bar.Most circuts are the old cloth wire with no ground,the kitchen looks as if someone before has ran new wire to all outlets.
Old 04-29-2009, 11:24 PM   #4
Are you sure that the panel is a sub panel?
If it is your main panel, with no disconnecting means before it, neutrals and grounds go together.
If it is a sub and you only have a 3 wire feed to the panel, you have three options
1. Run the circuit to the main panel
2. Install a new 4 wire feed and separate the grounds and neutrals.
3. Do what they did.
Only two of the three are code compliant.
Old 04-30-2009, 08:43 AM   #5
If you want the chance of being fried, you would go with answer 3.
rgsgww is offline   Reply With Quote
Old 04-30-2009, 09:24 AM   #6
joed's Avatar
Neutral wires are only allowed one per connection. If there are two neutral wires under one lug it is wrong.
Do not PM with questions that can be asked in a forum. I will not respond.
OLDER HOME, 100 amp box etc.. BADAZZVOLKS Electrical 2 10-29-2008 03:36 PM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 08:04 PM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
Guide: Adding curb appeal! Grumpy Remodeling 1 12-31-2003 01:26 PM
