Adding Lights To Existing 3-way Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2014, 11:07 PM   #1
Rewards Points: 38
Adding lights to existing 3-way circuit
Hi guys,
My basement (added in the 20's) has very low clearance, about 5'10" from ground to bottom of joists, and about 5'4 from bottom of wooden beams to floor. I regularly run into the hanging light fixtures that are present now.
I started replacing these with shallow IC fixtures w/ LED today and decided that I'd like to add a few more lights.
I am adding them in an odd layout so my real question is this... where in the circuit should I add in the additional lights? The push-lock connectors on the Halo housings allow for 4 total wires on each... is it unacceptable to connect the two additional lights from the closest light (see attached)? Or do I need to slave one from the existing light, then slave the second added light from the 1st added light?
The leftmost existing light only has 1 Romex wire run to it so there are two free slots on each of the orange connectors.
Adding lights to existing 3-way circuit-basement.jpg   Adding lights to existing 3-way circuit-asdads.jpg
chrisificti0n is offline   Reply With Quote
Old 12-27-2014, 11:28 PM   #2
Rewards Points: 58
Add them wherever is the wiring is easiest.
Eddiethekub is offline   Reply With Quote
Old 12-28-2014, 07:53 AM   #3
joed's Avatar
Rewards Points: 12,902
If all these lights are controlled by the same switch then you can add them by connecting into any of the existing lights.
Old 12-28-2014, 02:29 PM   #4
Rewards Points: 38
Thanks guys. I have run into a few things done incorrectly in my old home and I wanted to be sure that I am not creating more "wtf" moments for future generations.
Adding Ceiling Fan to Existing Circuit RalphPeters Electrical 1 12-02-2012 02:54 PM
Adding Additional Recessed lights to existing jay235 Electrical 5 11-08-2012 05:43 PM
Adding Light to Existing Circuit NEWJACK Electrical 2 05-11-2012 12:09 PM
Adding recessed lighting to an existing circuit Tombmt Electrical 0 04-21-2012 09:28 AM
adding lights mharwell01 Electrical 1 01-03-2009 03:59 PM
