Adding Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 07:18 PM   #1
adding lights
just wondering if someone can give me a quick answer. I currently have 7 receptacles and 3 lights on one circuit. the receptacles are in the living room and the lights are in the basement. I have just installed 6 recessed lights in the living room. does anyone think that that is too much to add to the circuit. not much gets plugged in in the living room T.V. couple of lamps dvd player, occasional vacuum cleaner.
samiller1980 is offline   Reply With Quote
Old 03-28-2010, 07:38 PM   #2
Master Electrician
Rewards Points: 3,676
Without knowing wattages and the rating of the circuit, the quick answer is you should probably add a circuit.
brric is offline   Reply With Quote
Old 03-28-2010, 07:45 PM   #3
Electrician
Rewards Points: 760
if you happen to live in canada then you must install a new circuit, which only allows 12 devices on a ciricuit.
darren is offline   Reply With Quote
Adding recessed lights in basement tbone2004 Electrical 8 05-11-2011 11:19 AM
Adding new circuit for recessed lights.... DickieFL Electrical 7 11-21-2009 09:12 PM
adding lights mharwell01 Electrical 1 01-03-2009 04:59 PM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 03:09 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
