Adding Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2009, 04:13 PM   #1
adding lights
im adding 2 flourescent lights in my basement off to the side of 2 existing lights. is it best or required to do it a certain way. Im not sure if its correct to continue the circuit around to where i want the new lights or if i can just pigtail at each existing light and run a wire over to where i want them. or is it ok to do it either way? also the lights im adding are the shop lights with a cord already wired so you can plug them into a receptacle. im thinking it would probably be best to remove the cord and just wire them straight into the circuit as opposed to installing outlets to plug them in to.
switch-------------O----------------O < existing lights/circuit
________________ O ______________O< lights i want to add
ignore the lines ^^
mharwell01 is offline   Reply With Quote
Old 01-03-2009, 04:59 PM   #2
Rewards Points: 150
ignore the lines ^^
Either way would be fine. I personally would run the cable from one light to the other and not pigtail. And I would probably hardwire the lights as well like you already mentioned. Sounds like you're on the right track.
Steelhead is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Adding lights to ceiling fan. 68MHJCs Electrical 7 12-29-2008 12:58 AM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 03:09 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
adding new outside outlets, lights etc walt1122 Electrical 8 08-23-2007 03:11 PM
