-   -   adding lights (http://www.diychatroom.com/f18/adding-lights-34999/)
mharwell01 01-03-2009 03:13 PM
adding lights
im adding 2 flourescent lights in my basement off to the side of 2 existing lights. is it best or required to do it a certain way. Im not sure if its correct to continue the circuit around to where i want the new lights or if i can just pigtail at each existing light and run a wire over to where i want them. or is it ok to do it either way? also the lights im adding are the shop lights with a cord already wired so you can plug them into a receptacle. im thinking it would probably be best to remove the cord and just wire them straight into the circuit as opposed to installing outlets to plug them in to.
switch-------------O----------------O < existing lights/circuit
________________ O ______________O< lights i want to add
ignore the lines ^^
Steelhead 01-03-2009 03:59 PM
ignore the lines ^^
Either way would be fine. I personally would run the cable from one light to the other and not pigtail. And I would probably hardwire the lights as well like you already mentioned. Sounds like you're on the right track.:thumbup:
