Adding A Light Switch In Paralell Off Of Aduplex Outlet In A 2 Gang Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 08:21 PM   #1
Adding a light switch in paralell off of aduplex outlet in a 2 gang box
I have one duplex outlet that is wired with 1 red and 1 black wires on the brass screws and 1 white on the silver screw as well as the ground to green screw.
I would like to add a light switch beside it to control a separate light source. The duplex outlet will not be controlled by the light switch.
How do I wire the light switch ?
There is only one wire coming into or out of the gang box ( 14-3)
Katsry is offline   Reply With Quote
Old 11-02-2011, 08:38 PM   #2
Where is that outlet and what is it used for? And this is in your house?
Billy_Bob is offline   Reply With Quote
Old 11-02-2011, 08:56 PM   #3
joed's Avatar
Rewards Points: 13,298
Sounds like a split wired kitchen counter receptacle. You are not permitted to connect a light to this circuit. If this is not a counter receptacle post back and we can give you the directions. You will likely need to turn off two breakers to kill power to this receptacle
Newbie - fixing a switch and adding a light telechick Electrical 3 09-14-2011 08:59 PM
adding new light, to existing switch stiksandstones Electrical 25 03-12-2011 05:50 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
