Adding Light Switch - Outlet - Light > Correct Wiring ? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 11:25 AM   #1
Rewards Points: 85
Adding Light Switch - Outlet - Light > Correct wiring ?
Hi,
I want to add, in the following order, a light switch, outlet (always on) and a light that will be controlled by the new light switch.
The source will come from another light switch which is in the same box as the new switch I will install.
I just wanted to confirm that the wiring diagram below is correct for what I want to do.
I'm not 100% sure the outlet in the diagram is powered (on) all the time.
Thank you
westbank is offline   Reply With Quote
Old 09-15-2012, 11:27 AM   #2
Rewards Points: 2,516
no...the receptacle is controlled by the switch in your diagram
hammerlane is offline   Reply With Quote
Old 09-15-2012, 11:35 AM   #3
In the below diagram The source power enters the configuration at the switch location, the receptacle is always hot and the lite is controlled by the switch. . I did not show ground wires for ease of drawing
Adding Light Switch - Outlet - Light > Correct wiring ?-new-bitmap-image.jpg
The Following User Says Thank You to hammerlane For This Useful Post:
westbank (09-15-2012)
Old 09-15-2012, 11:39 AM   #4
Rewards Points: 85
Thank you hammerlane ! Much appreciated. This will save me a lot of time.
Old 09-15-2012, 11:42 AM   #5
Here is another way using two 12-2 cables instead of one 12-3
Adding Light Switch - Outlet - Light > Correct wiring ?-new-bitmap-image-2.jpg
Tags
light , outlet , receptacle , switch , wiring
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 07:07 PM
Adding an outlet from a switch skdiy Electrical 18 01-15-2012 05:12 AM
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 08:03 PM
How to disconnect an outlet from a light switch mattjarvinen Electrical 2 08-26-2011 12:53 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
