-   -   Adding Light Switch - Outlet - Light > Correct wiring ? (http://www.diychatroom.com/f18/adding-light-switch-outlet-light-correct-wiring-156864/)
westbank 09-15-2012 11:25 AM
Hi,
I want to add, in the following order, a light switch, outlet (always on) and a light that will be controlled by the new light switch.
The source will come from another light switch which is in the same box as the new switch I will install.
I just wanted to confirm that the wiring diagram below is correct for what I want to do.
http://www.do-it-yourself-help.com/i...receptacle.gif
I'm not 100% sure the outlet in the diagram is powered (on) all the time.
Thank you
hammerlane 09-15-2012 11:27 AM
no...the receptacle is controlled by the switch in your diagram
hammerlane 09-15-2012 11:35 AM
1 Attachment(s)
In the below diagram The source power enters the configuration at the switch location, the receptacle is always hot and the lite is controlled by the switch. . I did not show ground wires for ease of drawing
westbank 09-15-2012 11:39 AM
Thank you hammerlane ! Much appreciated. This will save me a lot of time.
hammerlane 09-15-2012 11:42 AM
1 Attachment(s)
Here is another way using two 12-2 cables instead of one 12-3
