Adding Light/switch To An Outlet - Am I On The Right Track? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 09:29 PM   #1
Adding light/switch to an outlet - Am I on the right track?
I know what I want to do, and it makes sense to me, but I thought I should check and make sure I'm not asking for trouble.
I have a bedroom wall with two existing outlets. They are combo receptacles where one receptacle of each outlet is always live and the other is powered by a wall swich - like for lamps.
I want to add two reading lights in the ceiling instead of using bedside lamps. My thought is to connect wires to the lamp/switched receptacle of each outlet on either side of the bed, run a wire partway up the wall to a new switch on each side of the bed, and then on up to the ceiling to power the lights.
So basically, I'm tapping into the existing circuit and adding two new switches and lights instead of lamps. Does that make sense?
kccougar is offline   Reply With Quote
Old 02-27-2013, 06:54 AM   #2
Rewards Points: 13,724
The part about using over head lights for reading lights has me thrown.
A wall mount or lamp works far better.
Fine for general lighting of the room but usless for reading.
Old 02-27-2013, 07:24 AM   #3
Rewards Points: 345
I too would not put reading lights in the ceiling, but by golly, it's your house. So...
If you tap into the switched half of the receptacle, you will have to have both switches on before your light will work. If you want only your new switch to control the new overhead light, you will want to tap into the receptacle half that is always hot.
al_smelter is offline   Reply With Quote
adding a switch to an outlet with two circuits jeffpeter Electrical 16 12-10-2012 08:38 PM
Adding An Outlet Off Of Switched light austinbblock Electrical 4 07-23-2012 12:16 PM
Adding overhead light from outlet adgjqetuo Electrical 5 05-28-2012 08:01 AM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
