Old 03-14-2011, 09:50 AM   #1
Adding a light switch.
I have added a door to a room and want to add a light switch by the door. I have run the wire and purchased two three way switches... I just can't figure out how to actually install them. All of the videos and info that I have found are based on new wiring. I have a light switch that is wired to an exsisting light. Is it possible to add an extra switch? or do I need to have the power running through both switches before it gets to the light? Thanks everyone.
rubberhead is offline   Reply With Quote
Old 03-14-2011, 11:37 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
you should be able to do this. I am assuming that you ran 3 wire between the two switches if not stop everything, else... I am guessing a little bit here but one switch box aught to have 2 cables the new 3wire and the old one to the light. in this box the white wire(if they did it right and its suspose to be marked) should be our hot form the light to the original switch, this hot will need to be sent to the new switch via the white wire (and marked) at the new switch this white wire will be landed on the black screw, and the other two wires (black and red) landed on the other two. back in the old switch box the 2 returning wires(black and red) will land on the 2 brass colored screws, and the black wire returning to the light landed onto the black screw.
If your original wiring is different than i have guessed please post a description of what u have
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
adding new light, to existing switch stiksandstones Electrical 25 03-12-2011 06:50 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Adding a light to a 3-way switch Richo Electrical 3 04-05-2009 11:29 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
