Adding A Light With No Ground. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2009, 01:13 PM   #1
Adding a light with no ground.
We are doing some minor improvements to our kitchen (paint, new floor, etc..) and would like to add a second overhead light to a 3 way switch. I have access to the attic space above the kitchen and think that running a new wire to a new box shouldnt be a problem. However, the problem arises because the wiring for the kitchen ceiling light is older and only has 2 wires (black and red).
Do I need a ground?
Any help you can offer would be greatly appreciated.
redtide2121 is offline   Reply With Quote
Old 05-29-2009, 02:22 PM   #2
joed's Avatar
Rewards Points: 11,998
By code you are not permitted to extend an ungrounded circuit. The entire circuit will need to be upgraded to meet code.
Old 05-29-2009, 02:34 PM   #3
Registered User
Termite's Avatar
Agreed. An additional light would not pass inspection if installed on the two wire system.
Old 05-29-2009, 03:02 PM   #4
bummer. i think replacing the entire circuit would be cost prohibitive. thanks for the input.
Old 05-29-2009, 03:17 PM   #5
Rewards Points: 80
He is not required to upgrade his lighting circuit or any other circuit in the house. Just run a cable from the existing light to the new light. You have no need to open the switch box. Make sure you connect the new cable to the new fixture just like the existing one. Make a little drawing so you cannot screw up. If the boxes are plastic just cut off the ground in the new cable. If the boxes are metal, connect the ground from the new cable to the box and fixture.
J. V. is online now   Reply With Quote
Old 05-29-2009, 05:13 PM   #6
Electrical Contractor
kbsparky's Avatar
Maybe in Canada they are required to upgrade the whole circuit?
Old 05-29-2009, 05:28 PM   #7
If you have access above I would run a new circuit
Connect the new light & the existing light
What else is on the circuit?
Old 05-30-2009, 12:04 PM   #8
Rewards Points: 80
This guys got a three way. Why complicate this and then have to help him rewire the complete switch loop. Run a new cable and install the fixture and be done with it.
Old 05-30-2009, 07:30 PM   #9
Ah, missed the 3 way
I just don't like 2 wire, only 1 circuit in this house had it & it was the basement lights & shocked me - a tingle, not too bad
Old 05-30-2009, 10:02 PM   #10
Registered User
Termite's Avatar
I agree, the existing circuit doesn't have to be upgraded, but that doesn't mean that it can be added to in a manner that isn't compliant with the modern code. The addition of the new light fixture requires a permit for sure. I don't have my NEC with me but the IRC absolutely requires that the new portions of work be installed in a code compliant fashion. Appendix J of the IRC covers this in depth under AJ501.5.1. Pretty sure the NEC's language mirrors the IRC, or vice-versa. The only caveat is that the local municipality may or may not have specifically adopted the appendices of the code, which are not automatically adopted when the code is adopted...They must be specifically adopted. Appendix J is pretty helpful when dealing with existing homes because it takes a lot of interpretation out of it.
Old 05-31-2009, 11:04 AM   #11
Rewards Points: 80
We can quote all the regulations we want. The issue is, why?
Do you think an EC would pull a permit to install this extra fixture? Even if he rewired the whole circuit? I think not. The permit and inspection would cost more than installing the fixture. A little common sense here is in order.
Old 06-04-2009, 09:39 AM   #12
thanks for all the replies.
to further muddy the situation, there is a junction box (modern 3 wire) on the wall in the attic @ 10 linear feet away from the old fixture box. would it make sense to run a ground wire from that box to the original lightfixture?
Old 06-04-2009, 09:53 AM   #13
Learning by Doing
Leah Frances's Avatar
If you're going to bother running a ground wire from the new JBox to the light, why not just run new romex?
I get permits for installation of my last light fixtures. Cost was NOMINAL. And the inspector gets another chance to see that I do quality work.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-04-2009, 10:10 AM   #14
i suppose i could run all new nomex from the JBox. wouldn't this then require me to rewire the switch loop?
Old 06-04-2009, 10:52 AM   #15
Rewards Points: 3,130
Bravo! Somebody who tells it like it really is. I'm not a contractor, just a skilled DIYer. I'd never in a million years pull a permit for such simple work, regardless of how nominal the fee.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Do I need to ground a pendant light? Rendulic Electrical 5 05-10-2009 02:17 PM
Adding an outdoor light qoncept Building & Construction 4 02-08-2009 01:37 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
