-   -   Adding a light with no ground. (http://www.diychatroom.com/f18/adding-light-no-ground-45525/)
redtide2121 05-29-2009 12:13 PM
We are doing some minor improvements to our kitchen (paint, new floor, etc..) and would like to add a second overhead light to a 3 way switch. I have access to the attic space above the kitchen and think that running a new wire to a new box shouldnt be a problem. However, the problem arises because the wiring for the kitchen ceiling light is older and only has 2 wires (black and red).
Do I need a ground?
Any help you can offer would be greatly appreciated.
joed 05-29-2009 01:22 PM
By code you are not permitted to extend an ungrounded circuit. The entire circuit will need to be upgraded to meet code.
Termite 05-29-2009 01:34 PM
Agreed. An additional light would not pass inspection if installed on the two wire system.
redtide2121 05-29-2009 02:02 PM
bummer. i think replacing the entire circuit would be cost prohibitive. thanks for the input.
J. V. 05-29-2009 02:17 PM
He is not required to upgrade his lighting circuit or any other circuit in the house. Just run a cable from the existing light to the new light. You have no need to open the switch box. Make sure you connect the new cable to the new fixture just like the existing one. Make a little drawing so you cannot screw up. If the boxes are plastic just cut off the ground in the new cable. If the boxes are metal, connect the ground from the new cable to the box and fixture.
kbsparky 05-29-2009 04:13 PM
Maybe in Canada they are required to upgrade the whole circuit?
Scuba_Dave 05-29-2009 04:28 PM
If you have access above I would run a new circuit
Connect the new light & the existing light
What else is on the circuit?
J. V. 05-30-2009 11:04 AM
This guys got a three way. Why complicate this and then have to help him rewire the complete switch loop. Run a new cable and install the fixture and be done with it. :thumbsup:
Scuba_Dave 05-30-2009 06:30 PM
Ah, missed the 3 way
I just don't like 2 wire, only 1 circuit in this house had it & it was the basement lights & shocked me - a tingle, not too bad
Termite 05-30-2009 09:02 PM
I agree, the existing circuit doesn't have to be upgraded, but that doesn't mean that it can be added to in a manner that isn't compliant with the modern code. The addition of the new light fixture requires a permit for sure. I don't have my NEC with me but the IRC absolutely requires that the new portions of work be installed in a code compliant fashion. Appendix J of the IRC covers this in depth under AJ501.5.1. Pretty sure the NEC's language mirrors the IRC, or vice-versa. The only caveat is that the local municipality may or may not have specifically adopted the appendices of the code, which are not automatically adopted when the code is adopted...They must be specifically adopted. Appendix J is pretty helpful when dealing with existing homes because it takes a lot of interpretation out of it.
J. V. 05-31-2009 10:04 AM
We can quote all the regulations we want. The issue is, why?
Do you think an EC would pull a permit to install this extra fixture? Even if he rewired the whole circuit? I think not. The permit and inspection would cost more than installing the fixture. A little common sense here is in order.
redtide2121 06-04-2009 08:39 AM
thanks for all the replies.
to further muddy the situation, there is a junction box (modern 3 wire) on the wall in the attic @ 10 linear feet away from the old fixture box. would it make sense to run a ground wire from that box to the original lightfixture?
Leah Frances 06-04-2009 08:53 AM
If you're going to bother running a ground wire from the new JBox to the light, why not just run new romex?
I get permits for installation of my last light fixtures. Cost was NOMINAL. And the inspector gets another chance to see that I do quality work.
redtide2121 06-04-2009 09:10 AM
i suppose i could run all new nomex from the JBox. wouldn't this then require me to rewire the switch loop?
md2lgyk 06-04-2009 09:52 AM
Bravo! Somebody who tells it like it really is. I'm not a contractor, just a skilled DIYer. I'd never in a million years pull a permit for such simple work, regardless of how nominal the fee.
