#1 |
Adding a light to a four way
I've attached a picture of what I have going on(I think that's where the power is coming in and I think that's where the light is connected in the upstairs. So switch 1,2, and 3 control one light on my deck. (Switch 3 is in the basement).
--- switch 4 is in the basement and controls flood lights under the deck. What I want to do is somehow connect the lights from switch 4 to run with switch 3- which in turn would work with switches 1 and 2. Any help would be great!!! I looked at wireless switch controls but I think they are IR controlled and wouldn't be able to transmit a signal through the floor boards. (I really don't want to have to rip down drywall) Last edited by awakin; 11-09-2012 at 02:23 PM. |
#2 |
To make this work you need to find the box where the above light is connected and move the below deck lights feed cable to that connection box.
Do not PM with questions that can be asked in a forum. I will not respond. |
#3 |
How do I figure out witch box has the light connected to it? It's obviously switch 1 or 2.
#4 |
You need to open the boxes and try to investigate and trace the cables.
#5 |
if the power feeds to switch 3 in the basement the lights should go to the box with the other 3 way switch.
i would check the switch closest to the light upstairs between 1 and 2 first. |
| Tags |
4 way, add a light, wiring ![]() |
| Display Modes | |
| confusion with track light | stephenbishop | Electrical | 7 | 03-10-2012 02:37 PM |
| Adding new gfi and light switch | Greenie | Electrical | 16 | 01-18-2012 03:42 PM |
| Adding a light between a light switch and the receptacle it controls | jej2csi | Electrical | 3 | 11-24-2010 08:06 AM |
| adding light confused | MICHIGAN616 | Electrical | 2 | 01-20-2010 10:18 AM |
| Adding a light to an existing 3-way connection | nthomp16 | Electrical | 2 | 07-21-2008 07:57 PM |
