-   -   Adding a light to a four way (http://www.diychatroom.com/f18/adding-light-four-way-162709/)
awakin 11-09-2012 12:27 PM
1 Attachment(s)
I've attached a picture of what I have going on(I think that's where the power is coming in and I think that's where the light is connected in the upstairs. So switch 1,2, and 3 control one light on my deck. (Switch 3 is in the basement).
--- switch 4 is in the basement and controls flood lights under the deck. What I want to do is somehow connect the lights from switch 4 to run with switch 3- which in turn would work with switches 1 and 2. Any help would be great!!! I looked at wireless switch controls but I think they are IR controlled and wouldn't be able to transmit a signal through the floor boards.
(I really don't want to have to rip down drywall)
joed 11-09-2012 02:31 PM
To make this work you need to find the box where the above light is connected and move the below deck lights feed cable to that connection box.
awakin 11-09-2012 03:15 PM
How do I figure out witch box has the light connected to it? It's obviously switch 1 or 2.
joed 11-09-2012 05:28 PM
You need to open the boxes and try to investigate and trace the cables.
DannyT 11-09-2012 05:33 PM
if the power feeds to switch 3 in the basement the lights should go to the box with the other 3 way switch.
i would check the switch closest to the light upstairs between 1 and 2 first.
