Adding A Light Fixture Wiring Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 05:17 PM   #16
Welp...installed the light. Did a white and black pigtail in the outlet box, wire nutted the white in the switch box, and the black load line to the off (bottom) and light black line to the top of the switch. Light turns on PERFECTLY!
Thanks for all your help! Just need to get some romex staples to finish it to the wall.
draconius is offline   Reply With Quote
Old 02-24-2013, 05:54 PM   #17
Rewards Points: 2,516
Although functional it looks bush-league. You should of done the combination outlet/switch in the same box. A 4" square box and a combo cover is about $3.00 for both.
That romex should be protected...the vertical drops should be inside EMT.
Glad it works at least you learned something.
Also clean the lint/saw dust out of the handy box with the receptacle. In post #9 looks like good tinder at the bottom of that box
hammerlane is offline   Reply With Quote
Old 02-24-2013, 10:21 PM   #18
joed's Avatar
Rewards Points: 13,322
What is wrong with the cable going into the receptacle box? It looks burnt.
Old 02-25-2013, 05:50 AM   #19
looks like electrical tape...but why? Someone cut the sheathing too short??
Old 02-25-2013, 07:24 AM   #20
joed's Avatar
I think you are correct. I see what appears a mark on the cable where it was previously clamped. Looks like they moved the box down and didn't have enough cable in the box.
Old 03-01-2013, 10:56 PM   #21
The box was cleaned out completely. I plan on fixing all the electrical in the garage in the extreme near future. I needed a quick light switch for the tool area. once I run elec for the laundry area, I will be sheathing everything, rerunning a LOT of the wires, and following code.
Thank you for the assistance with everything!
You are correct. The previous owner (original owner) did some VERY interesting things with concrete and even electrical...he used white romex for outside! I need to get electricity to the back yard, so that is one of the next large electrical projects...also wouldn't mind upgrading to a 300amp box due to all the tools I have surmounted in the garage due to all the projects with a new home.
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Wiring up an overhead flourescent light fixture J S Machine Electrical 13 06-03-2011 04:00 PM
Mercury Vapor Light Fixture Wiring Hoppy084 Electrical 4 06-24-2010 11:38 PM
Help with Light Fixture - Braided Romex, possible Arc, is wiring safe? cntnick Electrical 5 03-17-2010 11:22 AM
My light fixture / socket question. Getson Electrical 13 02-25-2009 03:41 PM
