Adding A Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 03:58 PM   #1
Adding a light fixture
My girlfriend has a 16x60 mobile home that she has asked me to move into, and the first thing I noticed is that there was no light at all in the whole living room. I was curious if anyone knew anything about maybe getting a light fixture installed?
bravesfan0958 is offline   Reply With Quote
Old 09-02-2012, 04:16 PM   #2
Rewards Points: 13,694
Stick with some form of table lamp, or pole lamp plugged into a wall outlet.
You may even find one that is switched on from a wall switch.
There's no place to run the wires over head, (like though an attic) there's not going to be a good place to even install a fan box since mobile homes are so under built.
Old 09-02-2012, 06:15 PM   #3
Rewards Points: 2,516
Yes. I know something about getting a light fixture installed. But your failure to give any more detail other than your girlfriend wants you to move in limits the amount of help that can be given. So until you can provide other relevant information this is done.
hammerlane is offline   Reply With Quote
Old 09-02-2012, 10:49 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Mobile Home are diffent ball of wax to deal with it due they have few oddball items will show up what they used.
For the ceiling runners they will not use the standard demenison lumbers so more likely use 2X2 for it and the space between the ceiling and roof is very tight you can get new cable in place but NOT that easy without resorting punching few holes along the way.
If you have flat ceiling that may be little easier but if you have catheral ceiling it will get little more trickier but it the same answer as I menton above.
Also the other thing majorty of the mobile home will use the old work box style so when you try to remove the box from the wall there will be a set of screws which they will hold the box simauir to the oldwork box are even the switch itself is kinda oddball as well so expect that.
Merci,
Marc
Electrical Short in New Light Fixture amateur1 Electrical 14 04-10-2012 07:45 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 06:49 PM
Outside: Adding an outlet to a switched light fixture indigo Electrical 9 12-15-2009 09:48 AM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
