Adding A Light To An Existing 3 Way Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 09:41 AM   #1
Question
Adding a light to an existing 3 way circuit
I have a switch at the top and bottom of a stairway with the light at the bottom. I have mounted a light at the top of the stairway and ran wire from the switch at the top of the stairs to the new light. I can not get the light I have added to work off the exisiting wires in the upper switch box. It appears that there is no neutral wire there.
Please advise...thanks, Randy
rlferdig is offline   Reply With Quote
Old 09-16-2008, 10:15 AM   #2
Power Gen/RS Engineer
Rewards Points: 566
Appears? If no neutral exists, you'll have to get one (from the existing lighting circuit) to the new light. Whatever you do, DO NOT cheat and try to use the bare ground (assuming that this is romex) for this purpose. If your house has pipe, you can more than likely pull another conductor through the existing conduit.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 09-16-2008, 11:44 AM   #3
Hi Jimmy-
Thanks for responding. There is a switch for the kitchen on the backside of the switch I am attaching the light to. I would like to jumper off that neutral. Does that sound okay?
Let me know...thanks for your help, regards, Randy
Old 09-16-2008, 12:51 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
Hi Jimmy-
This would be a big no-no! The hot and neutral wires for a particular circuit must stay in the same race-way (or in this case romex/NM). You would have to wire from the light at the bottom of the stairs to get the neutral and hot wires. I am assuming you only have a black, red, white and bare ground in the switch box at the top of the stairs? Most stairways that go from a ground level to a basement level and has no 3rd level can be accessed from the attic (since usually the space above a stairway is largely un-useable). Id try and see if you can route the wire for the new light down to the light box at the bottom of the stairs.
theatretch85 is offline   Reply With Quote
Old 09-16-2008, 02:47 PM   #5
You are going to have to feed the new light from the existing light or the other switch.
220/221 is offline   Reply With Quote
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 07:16 PM
adding 3-way switch to existing circuit msahaydak Electrical 4 02-18-2007 12:43 AM
