Old 11-23-2010, 08:10 PM   #1
Adding a light between a light switch and the receptacle it controls
The bottom part of a receptacle in our house is controlled by a switch. I tapped into this circuit by adding a light fixture between the switch and the receptacle it controlled. Both the light I added and the lamp I plugged into the switch controlled receptacle are both flickering when I turned the switch on.
What do I need to do to fix the situation?
jej2csi is offline   Reply With Quote
Old 11-23-2010, 09:28 PM   #2
I=E/R
a7ecorsair's Avatar
Where did you get the neutral for the new light?
a7ecorsair is offline   Reply With Quote
Old 11-23-2010, 09:48 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Add to a7ecorsair's comment what colour conductor did you hook up to as well ??
Merci.
Marc
Old 11-24-2010, 08:06 AM   #4
Cutting one of the wires and hooking up one loose end to one light fixture wire and the other loose end to the other fixture wire is incorrect.
Where does the power (cable from the panel) come in?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
