Adding A Light To A 3-way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 04:08 PM   #1
Rewards Points: 462
Adding a light to a 3-way switch
Hi guys,
Having a little problem here and looking for some help.
In the basement stairway there is a light fixture at the top of the stairs controlled by 3-way switches at the top and bottom of the stairs. I want to add a light at the bottom of the stairs as well but I only have access to the switch at the bottom of the stairs. The fixture is all drywalled in so I can't easily run wire from there.
Is there any way to get power to the lower light from the lower switch. As I see it, it doesn't look like it can be done. The black screw is always hot and the other 2 screws alternate hot, so I'm not having any luck.
Any suggestions?
Richo is offline   Reply With Quote
Old 04-04-2009, 04:18 PM   #2
Cut, fish, patch.
You need to come from the other switch or from the light.
220/221 is offline   Reply With Quote
Old 04-04-2009, 08:19 PM   #3
joed's Avatar
Rewards Points: 12,002
If you only have three wires in the lower switch box you can't do it. You need to connect into the upper light or the upper switch. There is no way around it.
Old 04-05-2009, 11:29 PM   #4
Rewards Points: 462
That's what I was afraid of. Just a thought but I think I will scrap the idea.
Thanks for the answer.
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 08:32 PM
Adding a light switch.... truebaca Electrical 6 07-18-2007 05:42 PM
