#1 |
Adding a light
I'm adding a new wall light to my bathroom, and would like to either run it off existing switch to main light - or add a new switch next to old one. The old switch has just the one 12/2 with power. (I'd like to avoid daisy chaining the lights together - as access is poor). Thanks for any help. :confused:
#2 |
Adding a light
So now that we know what you want to do and what you want to avoid...what's the question?
#3 |
Adding a light
- i forgot that part!
![]() how do I wire off of the existing switch? Or can they be run off of the single switch - if so, how? Thanks! |
#4 | |
Adding a lightQuote:
Some older homes are not wired in accordance with current codes and may contain wiring schemes unlike that I described. If the existing wiring scheme is different from what I described then you'll need a different wiring schematic for the new light. |
#5 | |
I've got a single pole switch - with the hot (black) on the bottom and the white neutral into the top of the switch, and the ground...... that's it. Thanks..
#6 | |
That being said, you'll either need to a. runl 14-2 from the new fixture directly to the existing fixture or b. run 14-2 from the existing fixture to the switch box and from the switch box to the new fixture. |
#7 |
Adding a light
Pipeguy....If I went with your 'B' - how would the switch wire up? I've tried it a couple ways - with no luck as of yet.... thanks for any suggestions!
#8 |
Adding a light
The switch wiring doesn't change. At the existing light fixture: splice the new white conductor to the existing neutral wire (it's white, it hooks to the light and it does NOT go to the switch) and splice the new black conductor to the existing wire that comes from the switch (from what you said earlier it'll be white but it might be marked black or red). At the switch box: splice the two new white conductors together and splice the two new black conductors together. At the new fixture: connect the new black and white conductors accordingly. Don't forget your ground wires. I think this is the same as the 'daisy chain' circuit you referred to earlier. Last edited by pipeguy; 12-15-2004 at 11:12 PM. |
| Display Modes | |
| Trying to replace wall mounted light fixture | jtm2300 | Electrical | 4 | 08-03-2007 10:44 PM |
| Adding a light switch.... | truebaca | Electrical | 6 | 07-18-2007 05:42 PM |
| Part of a ceiling fan light fixture needs help...please | g5729 | Electrical | 1 | 06-17-2007 07:22 AM |
| Hot Light Outlets | Materials Guru | Electrical | 5 | 07-31-2006 08:11 PM |
| Replacing light killed downstream outlets, totally stuck | amissner | Electrical | 5 | 07-13-2006 07:02 AM |
