-   -   Adding a Hot Receptacle to a 3-Way Switch (http://www.diychatroom.com/f18/adding-hot-receptacle-3-way-switch-13624/)
rtyui2 11-20-2007 11:34 PM
I want to add a hot receptacle to a 3-way switch and have found a wiring diagram to show me the way. My question is, am I limited to just one hot receptacle or can I extend the circuit to other outlets, or even to another switch and light, or switch and fan?
RichyL 11-21-2007 12:11 AM
It depends on what all you have on that circuit. If you dont know you can turn off the power and see what is not working. Some 3 way switches you cannot tap out of because not all of them have a neutral, which you will need.
Andy in ATL 11-21-2007 04:00 AM
Not all of them have a constant hot either....which you also need. Do you have a constant hot AND a neutral?
rtyui2 11-21-2007 08:25 AM
It's a new circuit that I want to run in an addition to my house so there is nothing on the circuit yet.
jbfan 11-21-2007 11:19 AM
You are limited by the code in your area. Is the addition condisered a batroom, kitchen or bedroom.
If a kitchen, then you cannot share the outlets and lights.
If a bathroom, then you can share in some cases.
In a bedrrom you can share in all cases.
The best way to wire it is bring the hot into the recepticile first, then feed the 3 way switches.
Clear as mud eh?
joed 11-21-2007 05:54 PM
You are not limited to one receptacle. You can extend the circuit to other devices, as many as you like without overloading the circuit.
220/221 11-21-2007 05:59 PM
And, like someone else said, make sure you have the hot AND neutral in that switch box.
joed 11-21-2007 06:01 PM
It's whole new non existent circuit. It can be wired any way he likes it to be.
RichyL 11-21-2007 06:26 PM
[quote=rtyui2;The best way to wire it is bring the hot into the recepticile first, then feed the 3 way switches.
Clear as mud eh?[/quote]
I agree with JB here although you will only need to have a hot to one of the 3 way switches, your travelers from the fed switch will carry the hot to the 2nd 3 way switch. If the 2nd 3way switch is in a box that you will be putting a single pole switch in addition to the 3way you WILL need a hot to the other box to feed the single pole.
Andy in ATL 11-21-2007 06:33 PM
Huh??
RichyL 11-21-2007 07:27 PM
sorry for the confusion. What i meant to say was If he has a single gang box with a 3-way that is fed here, and across the room a 2 gang box with a 3-way and a single pole in it, he will not be able to use the hot off the travelers from the 3-way to feed his single pole switch. Hope this makes more sense :whistling2: He will need a seperate hot and neutral at this point.
Andy in ATL 11-21-2007 08:08 PM
It does...I thought you meant the opposite. Don't be shy to call me out when I don't make sense!:yes:
Andy
