-   -   Adding hot outlets to 3-way switch (http://www.diychatroom.com/f18/adding-hot-outlets-3-way-switch-20183/)
KJG67 04-21-2008 05:38 PM
Thought this would be simple, but Iím confused. New construction in suburban Chicago. In the basement I have a typical light working off a switch at the top and bottom of the stairway. I need to add two hot outlets in a new box at the bottom of the stairs. I've got that box run and the two new wires pulled. The wiring in the bottom switch box though has me confused.
There is a red wire that come in one conduit, loops around the bottom (off-colored) screw on the switch and continues into another conduit. There is a brown wire that is attached separately to each of the top opposite screws and returns through the same conduit. And then there is a white and yellow wire that simply loop from one pipe to the other.
Can someone tell me which wires I have to use? Thanks.
joed 04-21-2008 07:31 PM
Use the white and either the red or the yellow. Red and yellow are probably two separate hot wires. Red could be a switched wire. You will need to test to be sure.
220/221 04-21-2008 07:35 PM
I'm guessing the yellow and white.....but is a guess.
Put your tester on it. Yellow should read 120V to ground (metal box) and 120V to neutral (white). Make sure it stays "hot" when lights are switched off.
goose134 04-22-2008 12:12 AM
I flatted houses in suburban Chicago for few years, and I can tell you that this is typical:
Brown wires are your travellers. Red is your hot feed. Yellow is your switch leg and white, your neutral. If you want to hit an outlet, use the red and white.
Kingsmurf 04-22-2008 04:43 AM
kingsmurf
wow ...conduit in an residence? . . .generally speaking here in kalistine it's
Romex roping after plenty fun with a " HoleHog"
also you wouldnt ordinarily find the neutral supplying a switch...3W or other wise . .though it may be in the box if convenient when it was roped
3W's nothing but the two travelers between the switches . .power into one end ( generally only the hot conductor ) and the switch leg off of the other 3W to the light
conduit in an home huh ? . . .I roger that...there is NO
Romex in this house . . .its all in pipe / flex / or MC cable
conduit huh . . .that sparky must have been a fellow over-builder lunatic as well
let us know how you worked it out
Speedy Petey 04-22-2008 07:03 AM
Chicago is conduit country. All houses are wired in EMT. Every bit of them.
Maybe someone has some pics. I have seen some AMAZING work.
All of it is completely stupid IMO, but amazing work nonetheless.
KJG67 04-22-2008 12:07 PM
I think Goose134 is right - the switch at the top of the stairs has the yellow wire where the red is on the lower switch, the brown in the same spots, and the white run continuous from one pipe to another. I'm going to try and work on it tomorrow and figure this out.
Yep, as Speedy said - all conduit PIPE, no romex. Major PITA!!! I hooked up a hot tub and had an electrician I met at a soccer game come and bend some tricky curves and do the final hookup - amazing - just eye-balled it and started making multiple bends - fit like a glove. Not really in an area I can photograph, but it was impressive.
Thanks for all the input.
BigJimmy 04-22-2008 12:49 PM
Pete-
It's Chicago; strong union. No to offend Goose or anyone else but the conduit requirement is a "union code." Pipe work tends to scare off the casual weekend DIYer.
BigJimmy 04-22-2008 12:53 PM
Goose-De ja vu??!:laughing:
Notice that the OP said that the red is looped to the 3-way? It is obviously the hot. It's powering the light circuit and then continuing elsewhere to provide power for some other outlet.
Jimbobalooee
