Adding A Half Switched Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2013, 10:01 PM   #1
adding a half switched outlet
I have some lights that are in my shop that I want to add a half switched outlet to run a florescent light. The lights are currently setup like this
source
light -- switch
----outlet with one side hot and one side switched I want to add this
light
light
I have been looking online at different circuit diagrams and none I have found are what I am looking for. Can this be done? It seems like it could if I run a 14-3 to the outlet but I haven't been able to find a diagram to follow anywhere.
Dan
Last edited by bn2hunt; 05-25-2013 at 10:07 PM. Reason: diagram is lining up correctly
bn2hunt is offline   Reply With Quote
Old 05-26-2013, 10:02 AM   #2
Rewards Points: 2,516
if all you need is a half switched outlet then check out doagram below
source
light -- switch
light
light
Have no idea what the above means.
hammerlane is offline   Reply With Quote
Old 05-26-2013, 11:46 AM   #3
Ok, I put something together on the laptop to display what I am thinking. Anything going to the outlet is new, the lights are displayed as currently wired.
Old 05-26-2013, 11:56 AM   #4
I noticed the drawing didn't look like I meant it to. The black to the outlet would be spliced in at the light not in the middle of the run.
Old 05-26-2013, 01:39 PM   #5
Still am a little confused as to what you are trying to do. Are you saying that lite "A" is existing and now you want to add lites "B" and "C"? And you also want the switch that control all lites to also switch 1/2 the receptacle?
Old 05-26-2013, 03:22 PM   #6
All the lights are existing I want to add the outlet, but I only want one of the plugins to be run by the switch and the other plugin to be hot all the time.
Old 05-26-2013, 06:45 PM   #7
And you have power coming into on of the light locations and a switch loop runnung to the switch?
Old 05-26-2013, 07:30 PM   #8
Yes that is correct
Old 05-27-2013, 06:54 AM   #9
See if this makes sense to you. I only showed 2 lights but you can see how to add the 3rd.
grounds not shown for ease of drawing
Old 05-27-2013, 10:51 AM   #10
yes that's what I was looking for thanks
Adding new GFCI outlet to existing light switch idzrvit Electrical 15 11-20-2011 10:16 PM
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
3way half switched receptacles Rhyno973 Electrical 2 10-05-2010 03:33 PM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 01:53 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
