Old 06-05-2012, 09:25 PM   #1
Adding ground to an ungrounded circut?
Here's my situation.. I have an existing basement electrical circuit.. One outlet, then two light switches going to junction boxes then basement lighting..
I wanted to modify / move the basement lighting, so I wired new outlets out of the junction boxes for plug in shop lights..
All of the new wiring is grounded - Wired up the junction - incoming power to the junction is grounded.. Wired it all up..
Went to test the outlets to make sure all was done right.... No Ground..
Checked all the wiring to find:
The first outlet (before the light switch) is grounded.
The wire from the first outlet to the light switches was not grounded - with no ground wire available.
The lights I'm installing warn to make sure I'm using grounded outlets..
Well the light switches are dry walled in so re-running that power wire to the switches is a huge pain the ass..
Can I run a single wire (same gauge is the circuit) in line with the circuit wires from the first grounded outlet of the circuit, to each junction box to ground the rest of the circuit?
See attached file for an illustration of what I'm wanting to do..
I've read that to ground an ungrounded Circuit, you can run a wire from each outlet to the breaker box to retrofit a ground. Essentially, I've done 9/10ths of that already.. I just need to bridge the gab so to speech..
I want to make this as right as I can, but I'd hate to have to tear into the drywall to fix it.
Is this a safe solution?
Thanks a bunch ~Ian
learmoia is offline   Reply With Quote
Old 06-05-2012, 09:29 PM   #2
Lic Electrical Inspector
electures's Avatar
Re-feed the receptacles from the grounded JB and be done with it.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 06-05-2012, 09:42 PM   #3
E2 Electrician
stickboy1375's Avatar
I concur, refeed the receptacles, and just use the wires going to the switches as switch legs, and disconnect the old ungrounded feed going to the switches....
stickboy1375 is online now   Reply With Quote
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
adding a ground to an ungrounded recepticle SS396 Electrical 41 09-16-2007 05:56 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Adding a ground bar Chemgeek Electrical 1 02-18-2007 01:28 AM
