Adding A Ground Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2007, 04:44 PM   #1
Rewards Points: 20
Adding a ground bar
I am doing the electrical in my unfinished basement. I recently passed inspection for the rough-in but the inspector suggested I add a ground bar to my service panel since the slots on the neutral bar are nearly full. I attached one to the bottom, but am not 100% sure how to connect it
1) Should this be connected to the neutral bar?
2) If so, what's the best way?
2) If it is connected to the neutral bar, can I connect both ground wires and neutral return wires (white) to this bar?
Eric
Chemgeek is offline   Reply With Quote
Old 02-18-2007, 12:28 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hello Eric
If this is your main service equipment panel with a main breaker disconnect ( not a sub-panel) then the neutral bar is already bonded to the metal of the panel can. Simply by installing the ground bar with the mounting screws into the metal of the panel joined it (bonded it) with the neutral bar. Some companies (square d) use a green screw to bond the neutral bar to the metal of the enclosure and some use other designs. So as long as you used the correct ground bar for the panel and mounted it with the proper screws that came with the ground bar then you can connect white or bare or green or all three to that bar. If you used screws such as sheet metal screws then the ground bar is not installed in compliance with electrical code. You can also, if the panel spec sheet specifies, connect two solid ground wires of the same guage in one hole of the current neutral bar. Sometimes this is an easy way to get more spaces available. You must only put one neutral (white) per hole however.
Stubbie
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
Electrical ground redline Electrical 12 06-27-2006 07:09 PM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 02:32 PM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 08:16 AM
