Originally Posted by babyjesse2
i have a airconditioning breaker on the side of my homE currently on 60 amps.. i wanted to add another breaker for an electrical cooking range that im installing.i dont want to run any wires from the otherside of my home to the other.... so can i just use the 220v thats already there for the airconditioning compressor and piggy back the red/blk wires and the ground to the new breaker would that be safe and would it work...also what gauge of wire should i use... its a whirpool household glaSS COOKING RANGE THANKYOU!!
No due majtory of the ranges are required netural conductor anyway beside few counter top units are straight 240 volt sans netural it can get by with it.
For your extsting A/C circuit I am pretty sure that is two conductor sans netural so I will NOT bother try to hook it up to your range better off just run new circuit for your range and be done with it on codewise and it have to be full 4 conductor cable or conductor in conduit one of the two.
Merci.
Marc
