Adding GFCI Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 10:46 AM   #1
Rewards Points: 12
Adding GFCI outlet
Hello,
I have a non-GFCI outlet in my kitchen that I would like to replace with a GFCI outlet. The current non-GFCI outlet is wired to a light switch in the same box on the same circuit. The instructions that came with the GFCI outlet don't illustrate how to connect with this type of configuration. Could anyone please help provide me with proper wiring for the GFCI outlet? I've included a diagram of the current setup. Thanks very much in advance!!!
thearchitect is offline   Reply With Quote
Old 11-10-2013, 10:58 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It gets wired the same way as your picture shows, just don't use the 'LOAD' side terminals of the GFCI.
The Following User Says Thank You to stickboy1375 For This Useful Post:
thearchitect (11-10-2013)
Old 11-10-2013, 11:00 AM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
blacks and whites both to the line side of the GFI ... leave the yellow tape alone ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Old 11-10-2013, 11:02 AM   #4
Rewards Points: 12
So I should wire nut both black and both white wires to the LINE side of the GFCI?
Thanks for the quick response!
Old 11-10-2013, 11:03 AM   #5
E2 Electrician
It will probably make it easier if you pigtail the splice, but it's not required.
Old 11-10-2013, 11:05 AM   #6
Rewards Points: 12
Will do! Thank you!
Old 11-10-2013, 11:06 AM   #7
Rewards Points: 516
Yes .. GFI's have the good back wire for 2 wires each ...
Tags
bx wiring , gfci
adding additional outlet to GFCI John Troxel Electrical 1 08-28-2011 03:23 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 02:49 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
